dom14
Thanx for posting the above info mate.
Do you have an aftermarket temp gauge fitted?
Sure do. I've never trusted the stock ones in any of my fourbies. They're just too lazy, often by the time they start reading hot, your already well over 100c. My old hilux once got to 130c on my aftermarket gauge, the dash gauge only showed 3/4.
Shouldn't the "healthy" temperature be bit higher than 84?
I've been thinking all this time it should be around 90 degrees or so.
Not too sure, but it's the right thermostat for the motor. As long as your using the recommended oils it shouldn't be an issue. Newer motors often run at higher temps. I for one am happy it runs so cool anyway.
Another question popped into my head is that I haven't been aware the fan clutch is a temperature controlled type.
Yeah they are temperature controlled. There is a bimetal spring type thing on the fan. Not sure how exactly it works, but when this heats up it causes the clutch fan to start locking up. So after a good flogging mine will come on for 30 seconds to a minute depending on how hard she's copped it and how hot it is, once it cools down the clutch goes back to slipping and it slows down and goes quiet.
