Ok 100 km/h is max for towing here in WA, 100 on the GPS is 105 on the dial from memory 2700 rpm in 4th (CRD).
110 on the GPS is 2700 rpm in 5th (CRD).
110 on GPS is 3000 rpm in 5th (DI).
Graham
Ok so what revs are you pulling in a ZD30 manual @ 100 kph
My auto pulls 2200 @ 100kph I feel thats a tad weak for towing
other than dead flat towing,
I think mine will go to 2400 rpm with the OD off @ 100kph
That doesn't sound right to me unless they are from a manual patrol
110 from 5th in a Di sounds wrong too
Going up the Murray sitting on 110Kph cant for the life of me remember see any of those numbers
Will be going again soon when Roofys on the road so I'll take more notice then
Speed versus RPM comparison between different vehicles is problematic unless the tyre size is also known.
1 inch diameter nominal (nominal as hardly any tyre dia are what the manuf say) will give as much as 4 KPH and 200 RPM
I understand my best options are to fit std 265 tyres, But I dont always go with my best options lol
Most here would run 285s and Im hoping I can get RPMs that way
Hey Peter, we are going away with the club to Denmark over Easter. My vehicle is similar to yours, although my trailer is not as heavy as your van. i will take some notice of RPM in different gears and also with OD on/off and try and give you some feedback next week. Cheers Tony.
My ZD30 DI auto with 285 tyres, OD of = 3000 rpm at 100kmh.
Threedogs, my daughter has the patrol, when i get it back i will post, but quite certain standard size. Paulg at 90 k i think around 2900 unlocked, about 2700 locked n in 3rd with the o-drive button off. If i can lock in overdrive at 90 the revs come down to about 2300 i think, but dont take that as gospel! Thought 2300 would be a good range to be in for torque?
Finally have the patrol home,tyres are 265/75 R16.
My mechanic has decided he doesn't wish to put in the auto trans fliud temp gauge as he has never done one and not comfortable with doing it. So has someone any recommendations for the installation of above and also a EGT gauge?
