Lift is as the same as when I've got it and brakes only stopped working when I fitted new pads and rotors (x4).
Thanks billsgu and yes I've have bled all corners Including the lsv more than once. Fluid is solid all round.
However I can stall the engine if I push that bolt above the stopper bolt in and hit the brakes. (Lengthening the spring) though I thought it was supposed to be the other way around ?
Sent from my HUAWEI RIO-L02 using Tapatalk
