If I use a 300 watt inverter,, would it say,, charge a phone faster than using
a USB outlet on 12v
a USB outlet on 12v
Now I have a 300 watt job if I insulate it with a piece of rubber matting
would it be ok to cable tie to the Cargo barrier using SS ties. Ive had it for ages
never used it. but there are no feet to mount it.
To soften vibration? Just make sure it still has good airflow, I know mine warms up when I'm pushing it - it's got a thermal cut out that I've never hit, but better safe than sorry.
Mine is mounted on the outside of my draws (behind the rear seats). It just had a little frame thing that I drilled screws through and into the draws, never had an issue.
I also made up a little plastic protection thing to help keep things off it/keep airflow around it and hopefully provide a bit of protection (my rear fuse block also sits there).
Something like this, but a bit smaller.
Attachment 62391
what size wire ?? would 6mm be ok from AUX to the Cargo barrier.
Easy enough to protect it, might even fit a small computer fan to
help keep it cool
Not sure what 6mm equates to, but 300w/12v is 25a, so 30a wire should be sufficient.
Pretty sure I ran 100-110a cable (cant remember exactly) from second battery to a fuse/distro block, and then a 60a cable from the block to the inverter.
Make sure to fuse things up close to the battery.
i bought a cheapie $98 chinese 1500w to max 3000w pure sine inverter and use it charge batteries etc and run the coffee machine its been in for well over a year now, copy below.
ORDER DATE
23 Nov, 2013
ORDER TOTAL
AU $98.10
See description
Order 1500W(3000W) 12V-240V Power INVERTER Car Boat Caravan
View similar items - ORDER DATE 23 Nov, 2013
View seller's other items - ORDER DATE 23 Nov, 2013
More actions - ORDER DATE 23 Nov, 2013
1 item sold by bit_deals
( 270955177129 )
Add note
ITEM PRICE:
AU $98.10
When I ordered the camper, I upgraded the Inverter from the original 600 watt to the 1800 watt model just for the coffee machine.
The coffee machine needs 1500 watts, that's a lot of power from the batterys, but it takes less than 2 minutes to make a coffee, so for my setup its manageable.
The first coffee machine I had was from Aldi about $75, not bad coffee.
I now have a Delonghi one a lot dearer, but I don't have to clean the milk frother every time I use it, a quick rinse and the hole thing with the milk in it can go back in the fridge.
Just received my 150amp manual reset circuit breaker for my 1000w inverter.
Looks more like and big enough like something that should be used in my house. lol
