Some miscellaneous stuff..
A really good accessory to have is a wideband gauge that indicates your air/fuel ratios under different conditions. With a turbocharger added, this becomes indispensable, IMO.
I chose the Innovate MTX-L. It also has a narrowband signal output that I'm using connected to the ECU in place of the factory sensor signal for closed loop operation.
I mounted it here with my trans temp gauge:
http://i257.photobucket.com/albums/h...psed1d1b58.jpg
I welded a bung into the exhaust ~400mm before the cat - where the extractors form a single pipe. I'll use the same location for the turbo.
http://i257.photobucket.com/albums/h...psb46a4aea.jpg
One of my biggest concerns is detonation. There's no doubt that this has been the cause of most TB45E turbo issues with connecting rods.
Sure, you can strip your engine and beef it all up with stronger components. It's all a question of how far you want to go with it power wise and how much money you want to throw at it.
This is a thread about a low boost budget install so it's going to be using stock internals and we're going to do our best to keep that engine safe by other means..
Enter the visual knock detection device. These are sold on Ebay by a guy in Lithuania who makes them himself. They have good write-ups and my friend Jose in Panama confirms they work well with the TB45E factory knock sensor.
They will show a green LED when all's good and progressive orange LEDs when knock begins then a bigger really bright red LED when knock occurs.
I plan to use it as a visual aid i.e. have it more or less in line of sight so I can lift off when required.
I paid $20 extra to get the 5v output signal with it so if it indicates regular knocking, I'll log it to see why and when it's happening and adjust the Xede accordingly.
This is the size compared to my phone:
http://i257.photobucket.com/albums/h...ps906e573d.jpg
