bindi
Hi Mudski, I bet you've got a reverse camera linked into your double din unit?
Display cuts out occasionally
•If the screen goes black when you apply brakes or indicator, this is related to the reverse camera trigger wire cause by small voltage jumping to the trigger wire from the brake light or indicator.
- A common inline diode such as Part#: 1N4001 - 1N4007 will need to be added between the trigger wire and the reverse light positive. Ensure the diode is around the correct way.
Its an easy job and I have one of these diodes spare which you can have if this is your problem. Save pissing around testing earths etc. My dig options double din system did this until I put the diode in. The diode fits in the live feed from the reverse light to the din unit (easiest place to fit is in the back near the reverse light)
Mark
