Yes limp for no reason, NADs? What's that? I've been kicked in mine a few times over the years
Nissan Anti Detonation System. Boost/EGT gauge, Dawes/Needle valve, EGR plate and a catchcan. Could also include ECUtalk, glowplug timer and a MAF voltage modifier.
If you know someone with the same model Nissan you could swap MAFs to see if that's what is causing your limp mode.
as above you take the thinking away from the ECU by installing a manual boost controller.
You can monitor any changes by looking at your boost and EGT gauges,
I must do Mod for any Di ZD30, and Cr for that matter
