Alitis007
Mate that nulon additive wont cause the auto to play up, i have used it in may cars with auto locking and solenoid locking converters and never had a problem. Some people like pentrite and others like the nulon just a personal preference. You could have had a hidden fault and now its starting to show it self.
If you want you can service and flush the auto your self but you will need to buy a 20ltr container of dextron 3. How i flush the auto is,
1. Drain the oil( i think there might be a drain plug on the sump) remove the pan and change the filter. I recommend you buy a kit with a paper gasket coz the cork ones can leak and you can tear the gasket if you over tighten the bolts.
2. Clean the pan and remember were the magnet sits, wipe it clean with thinners or acetone and tap the bolt holes down so they are flat again. Wipe the surface where the gasket sits again.
3. Buy some Permatex 3 aviation sealant to coat the surface of the pan where the gasket sits with a light film so it doesn't spill into the pan fit the gasket and coat the other side of that.
4. Wipe the auto were the gasket will sit with thinners or acetone and quickly fit the pan coz oil will run onto the surface it you take too long.
5. Fill the auto to the FULL HOT mark.
6. Find yourself another empty 20ltr container and remove a trans cooler hose.
7. Now you will need two people for the rest of this procedure, start the car and turn it off and see which way the auto pumps the fluid. You want the oil to flow thru the cooler/ coolers.
8. Once you have found the flow hold the hose into the empty container and start the car and put into Drive so the auto pumps the oil out, the oil at first will come out in a thick stream after 5 or 10 seconds it should start to become less so turn off the car. MAKE SURE YOU TURN THE CAR OFF AS SOON AS THE OIL STREAM IS NOT THICK OR YOU WILL BURN THE AUTO OUT.
9. Repeat step 8 until the oils clean a redish pink color and refit the cooler hose and refill the auto to full hot start the car get your helper to start the car and hold it in Drive check you oil level so its on the LOW HOT mark then take it for a 5 min drive and re check your oil level.
Take it on the free way and see how it locks up, in economy it should lock up at around 75 80 in power around 90 100, hope this helps
