The tyrepower guy is also saying a 50mm lift kit will help fix the problem... I'm going to chase him up tomorrow as he said if he regarding the orif=gional job he did if it did'nt fix the problem there would be no charge, so will see if I can get him to apply that to the offset caster bushes, on a different note, if the problem does get fixed by fixing the offset caster bushes, if I later decide to put a 50mm spring lift kit in it will it undo things he has done to date? or cause different problems?
