i can see the pics but they are life size haha
There are situations in the sand/beach driving that the auto front lockers will prevent you from turning into the track you want. It might be different on harder ground but if you spend a lot of time on soft beaches I would avoid putting an auto locker in the front. If you go for the air locker at least you can turn it off when barging in the sand becomes a problem. It gets frustrating trying to pull it out of 4H so you can turn but then you loose to much momentum and stop anyway.
