MudRunnerTD
Have a good think about whether you REALLY NEED ADJUSTABLE SHOCKS???
* => Are you a guy that understands suspension setup??
* => Do you know how your vehicle should ride?
* => are you competent to dial in your shocks individually to each corner of your car?
* => Do you understand the requirements of your vehicle once you load her up?
All of the above questions should be answered by each of you honestly to yourself. I dont care what the answer is, i am not going to drive your car.......
By buying manually adjustable shocks you are basically stepping back in time, disregarding the decades of Shock absorber development that companies like Old Man Emu and Bilstiens have put into their product and saying "fark it, you dont know nuffin" "I can dial my shocks in better than you can design yours"
Who thinks that???
If you consider that the latest Old Man Emu shock (Next Generation of a world class product) has an infinitely variable valving system that adapts to the shock input on a input by input basis and will remain variable for the life of the shock.. How can an adjustable shock compete with that??
ie. When your vehicle is empty your shock will perform a certain way, when it is full it will perform another,Over slow speed versus fast, bumpy versus corrugated. Input by input it is variable. How can an adjustable shock even dream of being this adaptable?? How can we as car owners pretend to be better than that science?
I run 12 stage adjustable BOSS shocks on my GQ because i have an Ohlins setup on my Road Bike and understand the minute adjustments on that shock, i weight the same all the time as does the bike and all i really do is dial it in 1 or 2 clicks depending on my environment.
On my GQ this is pretty well undoable.... I was kidding myself to think there was benefit in going an adjustable over a refined and developed variable valving shock. I know what i am doing and basically set the shocks and forgot them, i am unlikely to adjust them again and i will adapt my driving to how the car handles rather than the shock adapting to the environment. Yes I'm a Goose. I will be replacing the shocks when they are knackered with a variable shock of the best that i can afford.
Its pretty basic Science really, A mono set shock versus a infinitely Variable Shock?????
Go with the Pros!
