MudRunnerTD
Hey Mego your kit looks good mate and drew has called well on a winch extension strap, the bigger the better.
I would also recommend keeping your snatch strap in a small bag by itself as it is likely to be used more often and you don't have to sig it out of your bigger kit. When out and about mine lives on the floor in the front left under the Navis legs.
My winch gear lives in the footwell behind the front passenger seat in easy reach. When you need it it is likely that you are situated precariously and need to hold the brakes on Hard and need to reach it and hand it out the window. If in a Bog Hole(don't do it) you also need to hand it out the window so keep it close.
