Hey ppl just in the midst of doing a zd30 to td42 conversion and chasing a set of chassis mounts and also the steel brackets that bolt onto the block. Any help would be greatly appreciated.
Brodie
0427828253
Brodie
0427828253
ordered my lift off ebay today, think it is a very good chance they will be installed on the week end coming. Will let you know once they are all off Timrob
what model?
Cool thanks man
I know some people are offering them to you but new springs are cheap like 200 a pair
Yeah i know nissannewby but i'm on a very tight budget man the misses doesnt want me to spend anything at all on it, but when you can not fit a normal can of coke between the top of the wheel and the guard you have to find ways around it. I was think of buying some blocks to correct the sag but the springs dont look to good anyway, so i just asked the question and hey presto i got some guys offering some help thank you
Looking for used Trim box for my Patrol GR Y61 2,8 TDI.
KCR has one with art. nr 100-260 Master 1
Gday mate welcome aboard head over to the intro thread and say gday mate
No worries bloke. Are you doing the job yourself?
As the title says the bloke who owned my ute before me changed it to the bench seat and whoever did the job just hacked the console up to get it to fit. Cheers in advance.
Im after a nissan patrol 4.2 turbo diesel manual ute under $20,000
Timrob.
Nobody has asked yet if you are carrying weight or standard truck.
Factory springs are soft and will sag very quickly. Mine were stuffed in under 6 months. Ring Zordos I am sure John will have some behind his shed that are better than factory and probably free.
You can buy the chassis mounts from Nissan for about $80 I think. One of mine got welded on crooked and have been having lots of vibration issues.
I did a td42 conversion on my GU hand grenade and need a hand throttle kit. Any help would be greatly received.
Not to hard, 2 drop downs from collumn that hold a pivot point and bar. flexijoints bolted to the pedals and a rod going to the bar. Got hand controls in my dads patrol.
thanks mate - the factory GU td42 has a hand throttle from factory - looking to use original parts if I can to keep it easy. I think I need a td42 pedal also because I can't see where my ex-zd30 pedal has any point to mount the extra cable.
Have you purchased a set or still looking? I am about to begin making a set for my 2008 ST if interested we could work something out! Cheers Ben
Hey nissannewby yeah man doing it myself it will be my third set of springs i've done other ones on other cars tho.
Owen1200, i have a set of draws and a fridge in the back but the main sag come along when i hooked up my jayco outback caravan so in the long term i will be getting a heavy duty 2" lift for it when i can save enough and the boss lets me buy it
timrob
standard springs are designed to take the kids to school. If you are carrying a couple hundred kgs in the back plus another couple hundred kgs of trailer, it will be a waste of time getting standard springs.
There are always people with heavier springs they don't want, and if you ring Zordos Suspension, I am sure John will have some half knackered 2" springs laying around, which will allow your truck to ride level but also carry a bit of extra weight.
the other option is airbags, however, you will lose a little up-travel and therefore not my recommendation.
Also, GQ springs will fit as well. GQ springs are the same, except the GQ weighs less, so they sit up a bit. 2" springs off a GQ qill be 1.5" in a GU, and you may not have to change the shocks right away.
Owen.
Whoops,
Forgot about this ad, I have found and installed the new centre along with a "LOKKA".
Am I supposed to delete this somehow?
Hey Timrob, my lift kit hasn't arrived as of yet, still haven't forgotten about you.
thanks Biscuits anytime man its all good
G'day mate,
I found this on ebay today, hope it helps
http://www.ebay.com.au/itm/Mitsubish...item2a1908d650
No just ask for it to be locked as you have what you wanted
Tim
Yep,
I need the power window master switch,
the relay,
a glove box lock(dont need the key,
and a windscreen washer bottle .
I figure I'll try here first, before Fleabay.
PM me if you can help out
Mark
Hi Mark,
Where are you located... not 100% but I might have a spare window relay you are referring 2.
Have also removed your mobile number, feel free 2 put it back up, just remember the world can see it not just forum members.
Todd
P.S: I have not seen an intro from you yet, would be a good idea to post up an intro about yourself and your rig before asking questions or help for parts.
Wanting a original straight front bumper i can fit while i customise my bullbar.Anyone on the goldcoast area who wants to offload one of these? (or between brissy and the goldy) want one in straight and resonable condition.
Let me know how much you want...cheers
Paul:bananarock:
Brisbane north.
Have an old bullbar you can have for $100. Message me if interested.
Refreshing of advert
I am here: http://tapatalk.com/map.php?focnja
ooo i was thinki9ng about something completely different, your talking about the idle knob, your best bet would be to find one at a wreckers etc.
Hi
I have an almost brand new set of standard springs for 2010 GU patrol. These were taken off soon after original purchase and are even still in box. Ideally i would like to swap for 17 inch rim preferably with tyre as i need a second spare. i am in Newcastle NSW if anyone is interested.
Brian
Awsum man thanks for that, thats no good bud i got my mate whos the owner of a panel shop and bas been doin repairs for over 20 yrs hes real good at wat he does so hopefully shel b rite bud......
Guys, I'm after a 5-Speed manual gearbox for an MK Patrol. Hopefully you're somewhere within a couple hours driving distance of Canberra (gearboxes don't fit in the mail slot :frown:)
PM me if you have a box available with where you are and how much you want for it.
-Lyle
hi all
looking for some maverick badges to go on to the front guards to replace the patrol ones that are on there now.
any info would be a good help.
thanks
aj and sarah
I might have some will check in the daylight
here try these much better than those stinky ford badges haha http://www.ebay.com.au/sch/items/_W0...sid=m270.l1313
Ummmm? Why?
Did yours come out as a Mav and someone before you converted it back to a Patrol? and you want to go back to the Mav? Bizarre? Hmmmm Maybe your having a joke around with the members?
Very Strange request, simply cant imagine why you would want to do that?
Hey Macca, on a side note mate, beware teh cheap Ebay chrome badges mate, i bought a heap of them when i did the respray off the GQ and the one i put on the bonnet was fully white within 6 months! the Chrome physically dissolved in the UV light!
came out as a mav trying to keep it as original as possable besides the lift kit and 33's
I have some still on the car they are red it is an early mav red badges.
yer i have an 92 mav it had patrol badges on the gaurds at the moment and half a ford badge on the rear door
got a new ford badge [joys of working for ford] what would you wont for the maverick badges 97_gq_lwb
cheers aj
