GU uses the same fuel pump for standard and long range main tank and I remember the GQ did the same
All the research I have done points to them giving me a fuel sender from a tb42s which is much different to mine.. and as I knew mine is the bloody expensive pump?
Now I have to bloody drive back out to Patrolapart again.... fwark this shits me..wasted bloody time!!!!!
Think I may deal with someone else in future.
Transfer pump is in the auxillery tank and pumps to mains
80 series use 2 separate systems don't they ??
Can't you put the low pressure pump into the long range sender units and your high pressure pump into the other sender for the standard tank ???
Do you need me to pick something up from Patrolapart for you....I have time tomorrow
Mic
Put a zd30 in it
No I need to return some stuff to them and sort this out first hand.
I know what the problem is and if the tanks were there same size I could just use the main as the aux but I think that would give me the shits!!!!!!
This is the sender they gave me.. has a large tube and small Attachment 40520
The is the efi oneAttachment 40521
The one on the right is the one out of my long range tank and looks like it was the original unit that is cut down to sizeAttachment 40522
Attachment 40523
