I run Nulon longlife in a 50/50 mixture. Change every 2 years..
Ran it for 8 years in my TB45 engine and now use the same in my TD42T.
Put the info & pics here.
http://www.nissanpatrol.com.au/forum...l=1#post647940
cheers.
hey mate
when you got your airbox from Fatz did you get them to supply the pipe work to the turbo as well or did you source from somewhere else?
do you remember what you searched on ebay?
Ill grab a link to the stainless elbow the clamps search for T bolt clamps
the other is just silicon hose, will put link here
http://www.ebay.com.au/itm/76MM-3-OD...YAAOSwNSxU2bO~
http://www.ebay.com.au/itm/3-0-inch-...4AAOxygj5SmDqo
http://www.ebay.com.au/itm/3-0-Silic...YAAOSwQItT8cmB
Or you can use silicon bends with small pieces of 76mm exhaust pipe to join
How long is the proposed wait on your ufi gear this time?
Item was in stock and supposedly already on its way....
All this stuff turned up today.
2 x genuine gearbox mounts
1 x genuine engine mount (drivers side)
1 x Superior engine mount (passenger side)
http://www.nissanpatrol.com.au/forum...2015/12/99.jpg
