@Dune, Thanks for all that info. I will be having the motor and tune preped by "White Hot motorsport" you might remember them from winning Targa Tas in their in house built GTR and Lambo, They have extensive R&D in the RB26 and know how to tune a motor for any application. I have 100% faith in White Hot to build and tune the RB26 to maximize it's performance for what i need. I'll be taking the Patrol to them soon for a Dyno run to see how much power and torque the TB42 is making now in RWD and 4WD and see how it ends up after the swap on the same dyno and ramp rate.
Back to the build:
The patrol is back on/off the road and it is SO much more drivable now with the low ratio gears, It's a pleasure to drive on the HWY and heaps beter off road now with the Spartan Front locker. As it in now with the 35's and the low ratio gears the speedo is a bit slower than the actual speed by about 10%, so to do 100km/h I have to be doing 110km/h on the speedo. This gives me room to play with bigger tyres if I want and still retain the factory speed. I had a little issue last night of a leaking water pump and I hope to get around to pulling it off tonight after work.
