If you fit a Dawes valve with your EGR blocked, it’s best to bypass the ECU control solenoid at the front of the engine bay, just behind the air filter. If you do this, you may also need to fit a small needle valve so that you can adjust and control the turbo’s spool rate. Also if you go with full manual boost control, you should limit your Dawes valve to no more than 15psi below 3000rpm.
THIS page should explain it all if you’re not sure.
Cheers,
