Just got a text from my daughter.[emoji38]
Attachment 85217
Attachment 85217
Yes yes I know, no religion and no politics. But the David and Goliath battle continues to amaze me.
Attachment 85228
Solid state batteries are a thing, now. Gotta be way better than a car that will burn for days. https://www.youtube.com/watch?v=PR5ilYz0C_I
Hellooooo!
Good evening fine peeps. Hows it going?
Thanks mate, I think its time I came back!
Its gonna be a GU. Would love to roost a 45 or 48 like a mad dawg but I'm gonna level up to a trusty 42.
always leave room to improve
Who ever thought looking for a rainwater tank would be so daunting! More sellers in Melbourne that you can poke a stick at.
Just rang the neighbour down the road for you Mark Mate, it was 2 x 10,000L ‘Polymaster’ tanks he just installed beside the house look great and strong. He said the same as you, was baffled with possibilities out there and ended up choosing them from other local owners best, longevity advice etc…. Higher end of the price scale but you can buy direct/delivered off their website to our area [emoji106][emoji106]
http://www.nissanpatrol.com.au/forum...022/05/149.jpg
If your after a gal or colorbond tank I got one from the tank factory while back and been sweet as [emoji106][emoji106]. . Can get it custom made with size and outlets wherever you like. . .
Fire wise, concrete tanks and or spring fed always full dams with a pump shed of say Hebel block build and feed lines well underground. Either way, decent quality diesel fire pumps properly sprinkler area protected please Philstar, petroleum vapooorises/bubbles up/stops under duress [emoji22]
Thanks guys.
Yeah looking at Colorbond tanks. Don't really want to put one in, water's cheap, but its council requirement.
Yes all getting developed now, have the bore and dam sorted, diesel pump shed and house/area dousing system, all remote triggered by GSM satellite, CFA compliant grounds. Should be protected. Tanks will be sprinklered and have block wall protection from radiant heat. Not necessary to go the concrete tank route based on BAL 29 from advice received.
Decide to just buy a cheap second hand poly tank. it will save me $2500.
Two calls yesterday , minutes apart from opposite side of the world and it was the same person. Mind blown!!!
http://www.nissanpatrol.com.au/forum...022/05/157.jpg
Where's @Clunk these days? I think he's driving a Paj now but still I miss his unique take on life.
Just watched youtube, https://www.youtube.com/watch?v=lbhxYIP9fg0. Scotty does not like electric vehicle, much. Now a study has shown that their extra tyre wear is causing more particulates to be released. Scotty makes a point that heavier cars will cause the already crap roads to fall apart quicker. Imagine the weight of an electric y62. They're heavy enough now.
Since Andy moved us to a new serve, has anyone else copped this at all?
It has occurred quite a few times.
Nup.............
Little Help Please Gurus [emoji120][emoji120]
Have been searching hard for a thread, discussion maybe to no avail [emoji26]
Was along the lines of W2A (water to air) intercooler setups and my shocking memory recalls @Touses Legend with a very suitable for my hopeful upcoming needs of a rear tray/under mounted heat exchanger [emoji120][emoji120]
@MB Lost my pics on this puter when it crashed, will check the other, maybe there.
Thanks Touses Mate [emoji120][emoji120]
Found them, moved them, now will try to attach them.Attachment 85567Attachment 85568TA DA @MB
Magic 🪄[emoji106][emoji106]
Looks like a great spot thanks heaps, are you happy with its performance back there?
Also can’t remember what W2A intercooler you were running under the bonnet [emoji120][emoji120]
Works like a charm, can't get the monster hot. Two 10" craig davies fans under it, coolant pushed about by 80lt? pm pump.
Operate it via switch on dash. Pretty much don't run it cold winter mornings 'til temp climbs to comfortable heater levels.
Ic is a frozen boost? out of the states. will find pics.
Believe it's a bosch pump, no idea of amps or pressure.
High pressure hose is 16mm id pretty sure
