well, that was a fascinating and well put together read, and I have a TB42 :-) Thanks Lindon and others.
Hi Lindon,
Sorry I can't answer any of your questions, hopefully someone else can.
I for one am interested and yes the more photos the better.
It seems like this is going to be another common fault with them.
Cheers Rodney
Posting this for Lindon and one else who might want to know.
We were talking about a leaking spill line and leaking diesel into your oil. This can also cause air to get into the fuel system overnight resulting in being hard to start in the mornings and having to re-bleed the diesel up. I havent seen any other posts on it so i thought i would get some pics up of the spill line inside the rocker cover.
With the rocker cover off there is a small metal tube that runs across the top of the injectors and bleeds the excess diesel back to the injector pump. The seals on this tube are known to leak and can cause the problems i mentioned above.
I have drawn the spill line in red on the photo below (this is after you have removed the rocker cover)
http://i1212.photobucket.com/albums/...ISSAN-ZD30.jpg
This is the banjo seal that leaks on the spill line, there is 1 on each injector and 1 on the output of the spill line (5 in total inside the rocker cover). You can buys these seals individually from Nissan pretty cheap.
http://i1212.photobucket.com/albums/...h/IMG_1511.jpg
While you have the rocker cover off, this is a good chance to replace your rocker cover gasket. Also check your glow plugs for wear (replace if needed) and the glow plug seals that leak on top of the rocker cover. The pic below is the rocker cover intact
http://i1212.photobucket.com/albums/...g_Rail_Los.jpg
This is the glow plug seal that stops oil leaking out from around the glow plug. You can see them around the glow plugs in the pic above
http://i1212.photobucket.com/albums/...132762W201.jpg
Hope this helps
Fletcha
Thanks for your input about the spill line Big_Fletch... that's fantastic for us all to know and see...
I look forward to adding more information/photographs when I fix mine in a few weeks...
Lindon
Thanks Superjuice and everyone else who has contributed to this post. I am in the same boat . symptoms were - oil level rising , provent catch can catching more oil residue than '' normal '' and on the odd occasion not starting with gusto , bit of hesitation . currently have cover off , return line off and while I am this far I will do the fuel return line mod as chaz describes . so new seals and stuff tomorrow . AAHH -the joys of motoring .
from the picture with coolant surge bottle, it looks like you have leaking coolant into the head area. the amount is very tiny, so you wont notice it easily. however, the surge bottle should be 100% full (cold or hot). not test can find out such problem. it happened to me, eventually replaced the head gasket.....
Thanks Trol3.0... good pick up! So, if the cap's integrity is OK and the bottle doesn't have a leak, then the most probable cause is a leaking head gasket, versus a cracked head, yeah?
I will fill the bottle again, and check it over the next couple of weeks to see what results are created... Thanks again...
Lindon
Hi Everybody...
Here is an update for your knowledge and sharing with others...
Today, I pulled the rocker cover OFF and replaced the banjo washers on the spill line. I will summarise for those people reading who may not be aware of the process. With the cover OFF, I primed the fuel line with the lift pump. No leaks visible. Maybe heat is required? I will continue to check over the next couple of weeks.
1. Pull the intercooler OFF
2. Pull the throttle body OFF
3. Remove the rail on top of glow plugs
4. Remove the rocker cover
Tips: Careful when pulling the rocker cover OFF that the little black plastic insulating-type inserts don't fall into the oil. Makes it challenging to find. Also check that the little metal rings on the glow plug seal, also doesn't unclip and fall into the oil, like mine. Double check all of them.
Anyway, some photographs for you to check out, including one of the T-piece, as Chaz describes, to route the fuel from the spill line, back into the return-tank line, by comparison to running it to the inlet side of the injector pump.
If you prefer more information, please give me a yell. Bit late at night and finding it hard to type a big story like I have in the past.
The vehicle is running very well. No engine warning lights. I have the boost set at about 14-15 PSI, EGTs are good, etc etc. I will continue to check on the oil levels to see if the new banyo washers leak. Also, I will continue to check on the water level in the coolant as described previously. Will report back if I notice any changes.
Thanks for everybody's input. I enjoyed the learning but most importantly, your experience and help with saving BIG dollars. If I had followed the advice provided by the specialists, I would now be $4000+ out of pocket. Oh, another thing. I plan to disconnect the lift pump at some point to see how differently it runs, and see if there are any differences or warning lights back ON. Stay tuned.
Kind regards,
Lindon
Ps. having trouble uploading the photographs which are more interesting... pdf, jpg, bmp, gif won't work... keeps recognizing them as tiff formats... will try again later... sorry
Try this:
Photo 1
Photo 2
Photo 3
Photo 4
Photo 5
Hi Gang,
Some further update for you all as a matter of interest...
The vehicle is running well. Very well. I haven't tried driving the car without the lift pump yet, so will get around to that one. But, just wanting to let you know that there still seems to be an increase in oil level on the dipstick, after changing the banjo washers on the spill line.
I dropped 250ml and the stick showed full - took it for a drive - dipped it cold the following day - over full - dropped another 250ml - took it for a drive - dipped it cold the following day - now it is just over full...
Do you think the injector pump might be pushing fuel out the front of it into the timing chain cover?
Kind regards,
Lindon
I had a similar problem with my gu111 with ecu coming on under acceleration and load. Thought it was fuel system injectors, filters,water etc. Took it to Sam Cali at round corner Dural and he I'd the problem with the electronics in the accelerator assembly in the cab. Replaced it and no more problems.
Hope this helps someone.
Waza
