ripper
Great that this has worked so well for everyone else, but somehow I've managed to mess it up.
I used Chaz's circuit, and found the right wires on the TCU for a GQ.
Now I desperately need help to know where to go from here. On my first test of the manual lock up nothing seemed to happen, then when I turned it off the TCU locked the converter up itself, but it dropped out again soon after. It stays locked for maybe half a minute, then cuts in and out a few times, then works for a bit longer again. Rinse and repeat for as long as I kept testing it.
I then bypassed the relay manually but it still has the same problem. All I can think of is that the relay failed somehow, and sent power where it shouldn't have.
Can anyone tell me what part is most likely the problem now? Lock up solenoid? Torque converter? TCU?
Thanks.
