Is this what I would need ? It says 4 inch on it so I would need to use a reducerAttachment 76987
How the hell am I suppose to fit anything there let alone 9 inchesAttachment 76991Attachment 76992Attachment 76993Attachment 76994
And another Attachment 76996
Yeah, air box manufactures that I have come across are Fatz Fabrication, Radius Fabrication (Both do GU, not sure about GQ)_U will have to ask them.
Millweld do a GQ airbox
https://www.millweld.com/a/Airboxes
Check them out.
The bloke that made mine, makes for GU TD42T and ZDs. Maybe he can help out.
Some of your pics are 1Meg+ could resize down to under 200KB
By the way did not say U needed a 9" pod. Just pointed out which one I procured, it showed how the base of the pod was blanked off and suggested that U need the pod filter with the small end dia to be facing the inlet port of air box.
Hope it helps out mate.
Thanks for the help it is going to be a bitch fight and I didn't want to do this until later but my intercooler piping is causing me trouble to get past the original ducting,it looks like I need to make up a smaller battery holder and muck around with a few other things as well
