SiberianPatrol
Ok, in the process of having the diagnostics run on the 4.2 I am considering swapping in. Here are the numbers:
Compression
1 = 25 bar / 362.59 psi
2 = 27 bar / 391.6 psi
3 = 29 bar / 420.6 psi
4 = 29 bar / 420.6 psi
5 = 23 bar / 333.59 psi
6 = 25 bar / 362.59 psi
According to the manual, the compression should be 29.4 bar / 427 psi with a minimum of 24.5 bar / 356 psi and a difference of 2.9 bar / 43 psi between cylinders. That makes cylinders 1&6 on the low end, but within reason but 5 is lower than the minimum. The guy has never regulated or adjusted the tappets/valves and lifters, so that could adjust the numbers slightly higher on the low cylinders.
It cranks perfectly when hot and supposedly cranks well in the cold, but obviously by the time it got to the shop it was hot, so hard to test that one. Mechanic pulled the dipstick and checked for exhaust back pressure to see if the pistons were excessively worn. It had a little exhaust gas come out, but nothing serious he said - acceptable and average for the age and kms on the engine.
I would like some input from the gurus here with the TD42. Is it worth dropping in this engine with the compression readings that I posted? Or am I asking for more trouble later on down the road in the form of a rebuild if I put this one in? Asking for advice here.
