http://www.ebay.com.au/itm/321421625867
Stainless Zip Ties don't secure very tightly. These can be pulled tight and folded over to positively lock.
Not too worried, I have a boost actuator here to put on soon.
Attachment 66967
No reason to have too many issues. Quality of the actuator is good, uses a piston rather than a diaphragm and the machining is good as well.
P.S Sorry for thread hijack. :offtopic:
Will start another soon.
Here you go the beanie size is in some of the first few posts.
Only cost $40 or so fits very snug. I highly recommend especially
if you have an Aux battery fitted.
As for the dump pipe I'd be getting it jet coated for max thermal result.
Keep the heat in the pipe and not transferring heat to other motor components.
Also found that gold tape cheap and effective
http://www.nissanpatrol.com.au/forum...=beanie+fitted
so what is this boost actuator . does it work off boost pressure instead of vaccum ?
