steve4377
Thanxs again people. Good advice all round. Gunna watch and shoot for the next month. Also gonna monitor fuel consumption rates. After about 80kph the extra go pedal is noticeable, but not alarming. See the rationale for the Dawes control but may just do a manifold clean every 50k if I remove the block.
My theory is that crud is mainly made of carbon. Carbon is a very poor heat conductor. When carbon is thick it retains massive heat and this causes the problem, more so than over fuelling. The heat creates local heat store areas than increase the local temp until the combustion chamber can take no more - classic reason maybe why the early failures were whilst cruising. Heat is the enemy and should be disposed of per design. Air passing through masses of hot carbon in the intake manifold must I would think raise the temp of the combustion gasses. Food for thought maybe. So if you fit catch can, Dawes and such then this may still not be enough if you don't clean out your manifold when you fit all those!
Interesting.
Steve
