Thanks ET.
Now back to smoking of a nice piece of pork and beef coated in crushed pepper and a dash of honey...
Thanks ET.
Yeah as said the override is basically an inbuilt relay so draws sweet f a amps when engaged, just needs 12v.
i have the sbi212 controlling my dual bats with an override switch for winching off both. works a treat have had the gq buried deep in nasty clay(tried to drive a dry dam) definetly helps having both batteries, be sure to use a good heavy cable to link them. also look at a hybrid type battery to better handle the high amp draw of winching etc im using a supercharge allrounder 100ah/700+cca. its a good simple system that works really well
I am reding most of the existing wiring so its being upgraded to deal with the amp load.
also consider fitting a heavier charge cable from the alt to main battery
Doing all that anyway as the BS 12 needs a heavy cable vs the current thing there.
Also making sure the +ve and -ve to the new winch are heavier vs the current ones.
The nasty bit is the controller, it's all plastic. So I have to make a metal backing plate so everything hangs on that vs a plastic one.
Additional query:
Is it worth while looking the two -ve battery terminals with a cable, same size as the +ve one?
At present both batteries are earthed at different points.
