Small amount is fine but don't make it a habit. Don't stress mate.
Locked hubs and in 4WD? For how far? They don't just break instantly. Normally the gearbox locks up after a while and you can't change gears. A mate who works for the RAA told me they get a lot of service calls from people who hire 4WD's (Troopies) as they drive them out in 4WD and come to a grinding halt somewhere down the road. The service guys just jack a wheel up and it releases the tension. If you are driving on the road and this happens just get a wheel on the dirt (or median strip) and pressure will be released.
Hi mate, I can't say for sure whether it's DMF in it. I reckon it isn't 'cos I heard somewhere a while ago that GQs didn't come with DMFs, but GUs.
I don't know whether it's true or not.
I think I'm about to find out.
I always thought I have no business touching the 4WD(low or high) without engaging the hub locks.
Well, it sounds like I need good crash course in 4Wd'ing. :D
Here I'm attaching the photos of the 4WD gear lever and the sun visor 4WD instructions.
It says not to engage the 4WD H or L without locking the hubs, yet I've been advised I can do it safely.
I may be confused here. Help me guys!.
You don't have to have the hubs locked, but you won't have the front wheels turning under power unless the hubs are locked.
Ok, cool. Thanx mate. I didn't make a habit of it. I reckon I've done it couple of times in the past. It went smooth, except when taking turns, obviously 'cos there's no diff between transfer box & gearbox to match the wheel spinning speeds.
BTW, when we use diff locks to get out of a bogged situation, aren't we stressing the diff and gearbox?
Does that mean the diff lock should only be used as a last resort?
Air/vacuum/electric Diff locks - If the ground is slippery or soft then there is no problem. If the ground is harder (dry outback road) then don't have it on. You only put them on when you see an obstacle or trouble ahead.
Auto lockers - when the pressure builds up they unlock (one side) to release the pressure.
Cool mate. I was thinking about modifying the diff to get diff lock effect for back wheels(manual switch), as I'm planning to head off
for a long trip, solo.Bang Head
I have no idea how to install an auto locker for a GQ. I'm guessing it's a professional job and probably an expensive job as well.
I would not bother for that trip, the factory Nissan LSD is the next best thing to being locked.
