Thanks Tony. My fan is working fine at all speeds.
Cuppa
Well today was the day! I've finally beaten the leak. Yay! Well actually 3 leaks that all combined to appear as one. No.1 was caused by the lack of 'little rubber socks' which fit under the grill panel, & into which Nissan's weird little plastic fasteners are pressed. Sealed with windscreen sealant. No.2 was the large rubber grommet on the firewall at the front of the passenger footwell. It had previously been used to run a cable. Sealed up the hole in the grommet with a piece of plastic stuck onto the grommet with windscreen sealant. No.3 - this was the real mystery, but eventually I found water seeping in through a small rust patch. To the right & below the big grommet are 3 little spot weld circles. One of them has rusted a little. Again I used windscreen sealant, & covered it with a piece of plastic bag, over the top of the hole. Shazam! A dry cab, even after 15 minutes of hosepipe treatment. Finally I can put the floor covering, seats etc back in. :smile:
Cuppa
Good job mate - my first attempt has failed (sealant around the windscreen seal) so it looks like the grill needs to come off ... grrrrrrrr ....
here you go kat have a read of this lot
Thanks for these ideas...
Katrol has a wet spot... so, so far I have plugged holes in the firewall around wiring, and now just wait and see if it's fixed.. Cannot physically see water dripping inside car but passenger floor very damp..
Cant do any more till I get home..
Thanks guys I have a leak also, I will try your suggestions and report back. Not looking forward to this as I am worried that I will be opening a can of worms. :frown:
I have the same leaking problem. Thanks for all the info on this thread. It gives me a place to start looking for the problem. Great to be part of this group!
An old thread but really good advice. Got the same leak in the same spot and see that the same screws are missing.
