That is quite interesting and quite the opposite driving style I had adopted to save on fuel consumption
Guess that is another reason to get to the bottom of this "black smoke issue" :)
Scangauge is here! Exciting days :)
Does anyone know if it is possible to program up a gauge to read MAF sensor voltage?
Hiya Kevin,
Every factory CRD towing Vans etc is probably doing the same temps, Cobber.
The CRD's run at pretty high dump EGT's out of the box.
Because of the large delta T across a Turbo, post Turbo EGT is only a 'guesstimate' to what the cylinder gas temps actually are.
I spoke with a dealer for Redback yesterday - they wanted some $1,300 for a 3" system fitted.
I have been playing with the new Scangauge. Most things seem pretty good but others I don't care for as much.
After I fitted it, I filled up with diesel (took 89 litres) and updating that was a pain and a half!
The other thing I cannot work out are the fuel consumption gauges. LHKM (litres pr 100Km) shows me using some 80L pr 100Km and AVG isn't much better.
I knew these cars are a bit on the thirsty side but this one really takes the cake :)
I chose DIESELa as the fuel type which I'm pretty sure is right.
Any ideas?
I'm in the same boat with scangauge mate and fuel consumption. I think I didn't read the manual properly, as there is a process to follow for most accurate fuel consumption and mine is all over the place. They are apparently very accurate if you follow the proper process.
