There's no way I'd do it that way. Once you take the pump out it's so simple to run any of the new easyout style of screw extractors into the two screws holding the black box on and it comes off. Absolutely zero risk of damaging wiring, injector lines or pump. Not a lot more work either. Mark the position of the pump before you take it out and make sure it goes back at exactly the same spot so the pump timing doesn't change.
Dave
