So it was the dealer that fitted the fuel rail, and now they're telling you its the fuel pump? It sounds as if they are using the the "Golden Wheelbarrow" method (Just keep replacing items until the problem is fixed), at your expense.
Kittle has most of the dealerships I think. They are half way through replacing fuel pump. Should have outcome by Monday arvo.
So if the dealer fits the fuel rail, new fuel pump and still it does not work are they going to foot the bill for unnecessary part replacements because it means the old parts were working.
Sounds like a run around.
Seriously they should check the ECU first. The rest are peripheral.
I will be fighting like hell for that to happen, threatening consumer affairs etc.
And, did they give you the "old" parts back?
It's a shame that your stuck mate,but whats worse is the fact that they probably don't have your parts they took off..wouldn't it be good if you could tell them if that wasn't the problem or faulty part put it back on then...for what is worth has anyone checked the fuel filter in the tank on the end of the fuel pickup?
I do have the old parts, insisted, the fuel rail is in the front seat and I walked into the workshop today and told the mechanic to keep the pump. There is flow from the tank so I think that's ok, thanks for all suggestions though, think the receptionist at kittles is sick of hearing "the guys on the forum suggest" lol
