Ok big day working on the shorty today. Learnt a lot of tricks and little bits of bits and pieces from my mate Stewie, who also let me use his hoist and help me (read that as do most of the work) work on the Shorty today. Cheers Stewie and have some Gentleman Jack with your name on it..
So today we :
Pulled the hubs down, and completely rebuilt the front swivel hubs, wheel bearing, kingpin bearings. Set it all back up and back together.
Everything got pulled down, cleaned and repainted to make it all look pretty :)
Front CVs are in perfect condition and really no signs of wear on them so that was an added bonus.
Car already had the GU locking Hub nut so I have a brand new set of them here if anyone needs them..
King pin bearings has just started to get that flat spot in the straight ahead..barely noticeable and it was obvious that the hubs had been pulled down before and had been looked after in the past by previous owners.
I spent a bit of time with shims feeling the difference in pre-load on the king pins so I could get an idea of how they should feel. Old mate Stewie did a dry one first to get a feel and picked the right shim straight away, but got me to have a feel with different shims to see how it should feel etc.
Also pulled the Auto Locking mechanism out of the front hubs (There is a thread about it somewhere) so they are no freewheeling or manually locked
Fitted the new front discs (slotted and dimpled RDA's), pads and twin spot rotors along with braided lines. Also fitted new anti rattle shims and shims (front and rear - cause I am OCD about it lol ) as part of the rebuild so they are as new as they can be.
Koni shocks got fitted up front and rear.
Fitted the rear HD Lower Arms
Did a few other checks like checking the the steering box which did not need adjusting at all, checked rear wheel bearings which were all good.
So end result...
First drive straight of the hoist, the brakes were as good as the old (original) setup
After 40 odd km now..they have more feel, pedal feels better and definitely more power so they will only get better
Koni shocks..all I can say is why didn't I got there in the first place. On road the car still handles well..may be a little bit more body roll but its very controlled. Harse ride that the dobinsons had is completely gone..small bumps it soaks up, big bums it does the same. The firde is firm, but not harse.
I think the easiest way to explain it is that it was disappointing to park the car tonight..I just wanted to keep driving it..it feels that good to drive and I think that's saying something about a 25 odd year old GQ.
Ok some pics of the work..didn't get many but got a couple
http://i1092.photobucket.com/albums/...l/IMG_0702.jpg
http://i1092.photobucket.com/albums/...l/IMG_0708.jpg
http://i1092.photobucket.com/albums/...l/IMG_0705.jpg
http://i1092.photobucket.com/albums/...l/IMG_0704.jpg
http://i1092.photobucket.com/albums/...l/IMG_0701.jpg
