cheers ET, have edited my post accordingly to prevent confusion for owners of other models.
Thanks, ET. I will have another look tomorrow. Obviously there is a problem with my set up. The breather must be blocked or the pipe crimped somewhere. My Old Trol is an RB30 '94 model if anyone has further info for me.
I had the carpet up and the fuel cover open to check something to do with the fuel pump today, and I traced all of the hoses that come out of the tank.
There seems to be no breather as such, there is a valve in the vapour canister line. The canister has a vacuum control diaphragm and a hose for the fumes to be drawn into the engine.
I have sometimes heard a momentary, weird noise as if air is being drawn past a restriction when the Old Trol is sitting under the carport. I suspect this valve may be not operating as it should as I still have a strong vacuum in the tank.
You will find you not allowed to let it breath to atmosphere
Back in 1974 they stop that
