Try using a hose at least you can then control where the water is going to further narrow it down.
Since posting this it still hasn't done it. It usually will do it every day, give or take, but not since.
Sounds like you have the dimmer wire connected to the indicator wire not the dash lights
Definitely not as if I did it would do it all the time.
So how did we go any news
Late reply but, I ran an extra earth wire from the earth of the indicator to the body. All fixed. Now when I press on the brake pedal, it happens. Not all the time though. I think I will run another earth lead from the -ive of the battery to the chassis and see what happens.
Bloody GUs and their earth problems.
I know Toyota earth different sections of the 4x4 like
engine bay, cabin and cargo area, motor to chassis and body to engine/chassis
but I suppose you can never have enough earth straps eh
Yeah I think I might do, -ive to chassis, and chassis to engine aswell. To be sure, to be sure...
Are you running LEDs in your tail lights? If so try replacing the high mount led with a standard bulb and see how that goes.
Yeah I am Rodney, but not all. But the original issue with the indicators was prior to the LEDs. The only globes that aren't led is the brake light on the barn door, the indicators and stop tails in the rear quarter lights. The rear lower indicators have resistors fitted. Do I need them for the brake lights too?
