OldMav
I have tested that particular air box option I wont write the name for obvious reasons, but they are hardly better than a ZD box, The first thing you learn with air boxes is the 30mm minimum rule for all round element clearance, Then you need some system of diffusion at the inlet point to force the air to use all the element for filtration. the FATZ or 4Bfab or any of the new panel element boxes now days are a good option which can be fitted to allow the second battery.
