Hey drew, maybe chuck up a pic of yours and we may have some suggestions
Heres mine clean. Nothing special. Most of the action is on the passenger side with the NADS, battery tray, compressor, air locker lines and catch can. Battery and radarc dcdc going in next week. Very clean.
Attachment 42849
This is the winch control box. It sits on a bracket made of mild strap steel, which bolts to original holes on the firewall and guard. The box is waterproof and is accessed by four easy screw locks and is way tougher than the original winch box. It would be a good way off fitting relays and other gear to weather proof it all. I have put plastic sheath on the cables since then, too.
Here is the control box for my W2A intercooler. It is a cast alluminium j box I bought from Farnell for $14, I just stuck a piano hinge on it, its water tight and comes in all sizes and very light
Its not in that position any more the airbox is there it fits nicely under the intake piping behind the head light
Attachment 42890
Attachment 42891
Agree with keeping it tidy. Nothing worse than digging around an engine bay and fighting to get around wiring and the likes. Loose wiring has a habit of rubbing against fittings and the likes and shorting out. A good trick with the wiring conduit is making sure the gap faces down as it will act as a channel for water and you will end up with water inside the cabin. Went for a drive with a friend and he complained about dripping water on his feet...a quick twist of the shrouding of his spotlight and UHF loom and fixed it quick smart.
