If you attempt this for the first time find any sort of scape panel from a car making sure that the drill bit is at least 25mm longer that the cutting teeth. Take it slowly and gently letting the tool do the job not pressure
I once installed a Safari snorkel on the GQ, I didn't have access to the ~90mm hole saw and didn't want to spend the money to purchase. Instead I purchase a new set of drills, drew an outline and drilled several (well lots) of small holes on the ourer circumference. It took a hole (pun intended) lot longer, but I didn't scratch my panel and saved some money on the ~90mm hole saw and ended up with a new box of drills! Food for thought. Fan of the velvet soap tip, will try that soon when I install the next snorkel!
hi skroony
spray aussie export tyre shine/ silicone spray with the engine running about 6 inches away from all joints 1 at a time if there is a leak the engine will increase in rpm for a second or 2 ..... no increase then nicely sealed :)
great tip thanks
