Usually not if castor correction bushes or drop boxes are fitted. I believe. As lifting the car brings the front wheels slightly back otherwise.
Happy to be corrected on this.
Back to op.
I think a 33 on the rear will be fine.. Along as your offset is fine.
35` tyres are pushing it..
That's on the weight side of things
might want to look at eastern wheel works wheels.
I run 285s and 305s on my 2004 gu with no problems ,mud flaps in place
You can move the front wheels forward 25mm with a spacer
Might just get a set of alloys off a gu8
16" tyres are cheaper and you'll get more variety
