Thanks, that's great!
You will kick yourself later on not going with a unit that is a good as Tekonsha.
For the sake of a few dollars the G-force extra no argument wins hands down.
Being able to set the amount of brake is easy.
But having it self adjustable is a Real extra that pays dividends the first time you need to brake harder that the inital setting.
Needing to brake harder than inital setting, with a lesser unit, the trailer is then pushing you onwards and your not totally in control.
Yeah you may get an over ride switch, but it's about reaction time.
You can get lucky and have sufficient time to react.
Having to brake all of a sudden and then remember to go for the over-ride switch when times in short supply, your then not concentrating on the rd and taking a hand off the wheel and possibly eyes off the rd also.
On the open rd you may never need the g-force option, but get into any town and some clown props in front of you!.
Then again out on the open rd & skippy jumps across the rd.
Are you putting the Family in the car?.
m2cw
Just installed my Tekonsha today.
I now have Tekonsha Primus controllers in my Patrol and Territory.
At $75 they are the cheapest of the Tekonsha proportional braking model range.
I chose the Primus because I am a cheaparse and also because I only have one trailer with elec brakes.
Piss easy to mount, do the wiring and the calibration is set and forget (for one trailer) or a little fiddly if you have a couple.
Works awesome on my 2 ton van.
I believe the other Tekonsha models like the Prodigy etc are preferrred if you are using several trailers of differing weights, one trailer with widely variable load or extra axles (up to 4) as you can select different setups via the menu, could be wrong tho.
I've got the Prodigy and its never let me down. I quickly set it depending on the load in the trailer and forget its there, it just does the job and the proportional breaking based on the rate of deceleration works well. Hit the breaks hard and the trailer pulls up just as hard, take it easy and the trailer does as well.
J.
