Robo
Hi guys,
Have the 70-85kph shimmy now, started out as death wobble, could'nt control car at all, I was just a passenger behind the wheel struth !!.
replaced all front end bearings, tierods x 4, yoko tyres on steel rims had 2" lift 2 yrs ago and ome nitro shocks, bit hard for the street +200kg constant load.(family car, and tow vechile)
dropped back to ome 30mm front and lpg springs rear,
replaced all rubber bushes, inc caster 2 deg in radius arms.
the only thing not done is damper, it look's std, taken it off and feels fine throughtout stroke.
I'd replaced this yrs ago on mk wagon with h/d rancho and recon to heavy, would not RTC and it suffered same wobble so I find it hard to believe replacing it on newer 4x4 not the answere.
However I have suspesions that the offset and width of rims might have something to do with it!
but replacing 16x8 steel rims with say 16x7 alloy and getting offset back to close to factory as possible is 2-3k gamble if I'm wrong.
The rims are from the Mk so the offset is for the front suspension of a leaf sprung and not coils.
I do know that the offset for bothe MK and GQ is +30mm as I have both gen manuals.
ANY SUGESTIONS ?.
at witt's end to what is causing wobble
