What heads knocking together?
Dirty dirty mind Gary!
Nah it was only rough on the faster rocky sections.
Mines got iron man shocks from the previous owner and what seems like pretty rigid springs where as a mate has toughdog springs and Rancho 9 way adjustables usually set on 2nd softest and his is like riding a cloud. (get you mind out of the gutter Gary!)
My D22 got fitted with Tough Dog 2" lift all around. So 4 shocks, leaf springs and torsion bars. NO weight in the rear at all, the leafs straightened out, and were on the borderline of a sad face. Got this replaced under warranty no questions asked. Then, torsion bars began making all weird creaky noises under flex, and front of the care started being stiffer and stiffer. Ended up being shocks stuffed and torsion replaced once again under warranty. This was all in a span of about 7k on the odometer.I must admit, great warranty side of things, as the shop I had it fitted at, got in touch with the supplier and supplier sent new bits in , no questions asked.
Anyways, after 4th time going back in, for leaf springs, I said no more. Ripped it all out, slotted factory stuff in, and few weeks later I got OME fitted. It hurt the wallet dearly, but difference between OME , compared to TG, and especially compared to factory crap, was day and night! Then on my 2nd D22, again OME, never had issues.
And more importantly when I got my patrol it was a no brainer. The OME 2" lift, completely transformed the car. I did have to go back in because they slotted in springs for a non winch bar, but that was replaced within minutes and now front is level.
I haven't yet tried it on extreme side of 4x4, but what I have done on and off-road since getting the gear fitted, I'm very impressed so far.
Just my 2 and a half cents.
I had OME 2" lift for 12000k's now and works fantastic. I think with any new suspension it is a matter of the correct set up in regards to the load ratings. ARB went through my hole set up to make sure the suspension was selected & set up correctly, I think this the main reason it works so well.
Some interesting reading, the OME's have a good following and are probably easily available at any ARB store across the country.
My choice of Toughdog's for the Patrol came due to some people we met on the Anne Beadell in 2010, they had done over 300000klm of touring and had worn out a Ultimate Camper.
They were on their second Ultimate that interestingly had Koni's on it from the manufacturer.
The tow vehicle as a 100 series that had Ralphs on it, 53mm twin tube with a 22mm shaft. Their opinion was they were the only shock they could get to handle the tasks they put them to.
The bloke reckoned he had tried and destroyed every other major brand and the TD's were the only one that has lasted.
Figured my loading of the Patrol would be similar to his, a decision I have not regretted in the 3 years of owning my Ute.
Like has been said it was loaded and weighed I got king springs to suit as well.
I run Dobinson springs and Koni shocks. As previously said, Make sure you pass on all relevant information to the supplier with regards to loads. That way it gives you the best chance of doing the job once.
