Lionel,
There are quite a few alternators for the SD33 in 12V on Ebay, with the Vacuum Pump on the rear, and these are up to $400.
Keep an eye out, and you may pick up another bargain......
Mic
Hello All,
Could someone please let me know what size and tensile strength and type of bolts are used to hold the SD33 starter motor in place?
I do not have a spare parts manual to be able to look up the correct information.
Since the vehicle did not come with a starter motor it strangely enough is lacking bolts that hold the starter motor on too!
Kind Regards
Lionel
Hi there. Look for parts from International Scout. The scout came with SD33 engine and it was 12V At least I heard it from som guys here in Iceland. I was thinking for a while about putting an SD33 in my patrol. But this 24V thing did not charme me so much. So Some guys told me about the scout. I was supriced that the americans really used an disel engine from nissan in their trucks.
Hello IceY60,
Wow my first message from Iceland! Thank you for the reply. International Scouts are pretty rare on the ground here in Australia now. The Jeep J10 also had the Nissan SD33 fitted as standard. No 24 volts does not seem user friendly when all the rest of my Land Rover system is 12 volts.
Thanks for the reply - by the way it is about 30 degrees Celsius and brewing for a storm here. Somewhat different from your weather at the moment I suppose :0)
Kind Regards
Lionel
I have a 24 V starter, $100 you pay postage. If it's 24 and you want to go 12, you need to change the edic motor and they are not the same as 24V.
You can PM me for details, all the best.
The ferret.
Ring gear is the same 24 or 12, 12 volt starter will fit, 24v starter will fit, edic motor is 12v on MK and 24v on MQ NA , MQ is lever, MK SD33T is cable operated, MQ SD33 has 3 positions on injector pump, whereas MKSD33T has 2.
Cheers, the ferret.
Hi Rodney, how's it going Mate?
I have an SD33 NA in the boat, it was 24V, is now 12V, and I have a cable with a 3 position Detent to operate the injector pump, pain, but better than the Edic motor when you are 50 ks out to sea!
I don't know how he would go registering the vehicle with a cable set up, I spose as long as it works it may pass.
I also have manual Glow.
The injector pumps for NA and Turbo are different, and as far as I know, the Edic is not swapable.
Keep up the good work there Rodney.
Cheers, the ferret.
Hello Ferret,
Thanks for the offer however I found out that the glow plugs have 11 volts written on them so it is a 12 volt system.
Do you know what size bolt holds the starter motor on? My vehicle did not come with the starter motor or the bolts.
Kind Regards
Lionel
