GU3_P@trol
Unfortunately the saga continues and some more advice needed!!
The vehicle ran fine for a number of months and then a few weeks back went into an underground car park and up and down a few ramps then headed back up the street and lost power again and spluttered and farted and shutdown multiple times on the way home. Next day no problem but thought it might be some crap in the tank that going up and down the ramps stirred up.
So vehicle was running fine again and I pulled the tank - spotless inside except for a small piece of foil from a injector cleaner additive bottle!. Connected the tank back up and here's where the fun begins! Soon as it was started got an engine fault light (77 - P7 code) and seemed to be in limp mode with no power all the time. shutdown and restart with the same result for a number of days. Went back to the tank and pulled the vent pipes that go to and from the check valve and blew all hoses out with air. rotated the check valve a few times to clear any liquid in it. Vehicle started with no engine check light, had full power and went like a dream for a few days. Checked all forums and found nothing on anyone having trouble with the check valves and Nissan said they have hardly ever sold any ($78 each).
Coming home from the Sunshine Coast yesterday the engine check light came on (77 - P7 code) and the engine started to miss and splutter and eventually died. Pulled over, restarted - spluttered and died a few times. Let it sit for 5mins and restarted and drove home with no problem.
The missus is a most unhappy camper and I'm unsure where to go next!! Any thoughts?
