Thanks mate, just checking so I don't put this new one upside down when I get it...lol
You can't fit it upside down mate. The taper on the ends won't let you. You can fit it back to front though. Technically there is no front and back though. When you fit it fit with the bolts that tighten you ends facing towards the back of the car rather than forward as the clearance around the bottom of the left side shock could be a little close mate.
Get it close to the right length then minor adjustment with a pipe wrench once fitted then tighten the tie rod end bolts. Happy days.
