That's the sort of list I was looking for
I don't like that list
You might want to add bush repairs to your list,
Watching a repeat of Myth busters they punched a hole through the front of a radiator,
Started the car and cracked an egg into it, stopped in a few seconds
@ lift
Why don't you like that list?
The only way I like my eggs is with bacon
That list was not a bible of what everyone should take but trying to cover all bases. then you select whats right for you.
everyone has different ideas on what to take, one of my first lists was $50 of beer an a tin of baked beans, go figure
Bad luck if the vehicle broke down
It's a decent list that can be used as a guideline and will allow me to create a list for myself. I have an idea of the things I want to I Clyde for a weekend or a several week long trip. Again with everything my first time camping I brought everything and as time went on what I took got smaller.
I read that list as a bit of a piss take to be honest! If it was to be given real consideration then I am with LiftLid. The problem is that that list is MASSIVE! The biggest problem most will face just before you leave is this:- what should I NOT Take. Because now I weigh 3.5t and have 600kgs on the bloody roof.
Work up a list of what you really need, what you'd like to take and what would be very nice to have... See what you can make work from the second and third list in the first list.
To be truly "self sufficient" you have no real room for luxury.
Working from the Worst case scenario backwards and the list will be real.
Welder,
Spare shock,
Fuel filter,
A set of mixed bushes,
A set of belts that fit,
A set of hoses,
Water in more than one place.
A Metric tool set. Leave the AF set at home.
3 different saucepans would not make my list. 1 also makes a good sink for doing the dishes ;)
You get my point I'm sure. A Newby needs to not be swamped for choice, they will do that all by themselves ;) they need guidance on what they Really need.
My 2c
