Mine aren't that flash lol
Photo of about half way through
Attachment 33078
Attachment 33078
Why not remove your Intercooler and pressure test to see if it has a leak,? easy enough to do
Do I need a special tool or some rags and an air gun?
Rags ,tape and a bike pump and a big bucket of water, don't need big pressures, so go easy
Haha yeah hence why I asked I didn't want to blow the ass out if it, don't need another 1000 dollar bill at the moment lol
If its leaking it would show up easy enough.
I'm not sure if that would be making a noise though,
but one less thing
@ Country GU could you please put what size hose clamps you have used ,
great info for other members IMo
thats just it sometimes you think it cant be found simply because you cant hear it over the engine.
but it is always worth a try none the less what have you got to lose, nothing.
if it is a leak under pressure you may find, idling it is now sucking air.
with a little luck you could see/hear water being sucked into the hole instead.
Are you loosing boost at all? Or is it just this noise up to 10psi and the car still has boost past 10psi?
The cars still got power, gets closer to 15 psi now with the throttle body cleaned, where it never used to which I thought was a bit suss. @threedogs, yeah mate ill throw them up probs tomorrow, gotta look at em and see what size I used lol but guess I'm off to find a dyno to find the noise after trying some other techniques.
