JUst ordered a plate from superior engineering to do away with the disconnect.. should be here tomorrow??
How bloody fast are you going round corners?? All it will do is try and step out IMO
Not fast at all you can feel the difference
Hey George,
actually i think the opposite is true mate.
I run no sway bar on the back of the GQ and disconnects on the front and No sway bar on the front of the GUIV and factory sway bar on the rear.
I am currently chasing a GU sway bar for the rear of the GQ for permanent fix and will remove the front. My GUIV is so much more comfortable to ride in with the back connected and the front is pointless.
Most of the flex is a Patrol is in the back, plenty of guys spend BIG BUCKS trying to get the front to flex and they fail. Sway bar is nowhere near as important of the front of a Patrol. back is where its at. IMO
My2c
My GQ has the factory rear disconnect (albeit stretched from the lift). I can definitely feel it if I forget to reconnect when back on half a road. I also like to have a play on faster gravel sections and she gets A LOT looser without the rear connected lol
sent from my phone using motor culture
I feel your pain. They got me for no front sway bar a few weeks ago, not even a km from my house. No defect, just a fine.
As said, disconnects for the front, leave the rear. I have found, that the front still doesnt move as much as i would like with the sway bar still bolted to the radius arms. If you want some sort of front end movement, lose the sway bar all together. The disconnects do help though, only slightly.
