I have checked the driver's door switch thru a multi-meter, the wire having the negative terminal is in closed circuit with the body of the GU. This should not be the case since all the doors are closed. I conclude that the negative line is grounded. I just can't find the point of contact at he moment. I got to find where the relay switch also, it could be malfunctioning.
