prospector78
Hi AB,
Where do you live?
I've been hunting the gold now for quite a few years now and heading out agian in a couple of weeks. The answer to your detector question depends on what you are looking for and how much you want to spend. If you have the coin probably the best detector on the market is the minelab gpx 5000 but you will be looking at between 5 - 6K. then there is the gpx 4500 or 4000 with the 4500 being the better of the two and you can pick them up for around 4 - 5k. If you are after big deep gold you can get a gp 2000, 2100 or extreme from $900 onwards but with these ones you are best to get them modded. And if you have more money if you get the 4500 or 5000 they will preform even better medded as well.
There is another detector on the market called the Garret ATX which sells for $4000 and is making waves in the minelab wold. All talk has that is is on par with the gpx 5000, but the jury is still out as this machine has just only been released in the last 6 months.
I think all states you need a miners right or fossickers permit, here in WA it's a miners right and costs $25 which lasts a life time. In QLD it's a fossickers permit which can last one month to several months. NT is also a miners right which by memory costs about $30 off the top of my head. As for Vic and NSW I'm not 100% sure as I haven't prospected there yet.
With the basics of detecting, do your research in the area you are looking at, look at previous history such as gold mines, what was found ie, nuggets minerals, what was mined. Also look at the topographics and types of landscape plus minerals in the area. While you are looking make sure that the area is accessible and see if you need permission. Hate for a farmer to catch you and get a bullet up the arse!!
When on the field, look for old detector holes, mine shafts, old timer workings, creeks and channels once you have found a good spot the key is to keep it low and slow!
Enjoy you'll be hooked with your fiirst nugget
Luke
