What threedogs suggests to do with adding up all of what you need power wise is something that is very important to do. A lot of people fit solar for the wrong reasons and also fit the wrong type of stuff for what they want to do. Solar, if correctly setup, is amazing if you want to be camping in an area for more than 2 or 3 days without driving and you dont want to run a generator. Up to that amount of days (from my understanding, please correct if i am wrong) a well setup dual battery system will be able to handle most peoples requirements.
What does everyone think of a system setup as follows:
have a main cranking battery linked to an agm or deep cycle type battery via a voltge sensing relay e.g. http://www.ebay.com.au/itm/PIRANHA-D...ht_1825wt_1156 , or a redarc (thats for you threedogs :)
Then have a marine isolator switch (e.g. http://www.ebay.com.au/itm/12V-24V-B...#ht_5558wt_969 ) joining the aux battery to the main battery to be used for winching or cranking.
Also have a relay attached to the earth lead of the vsr with a switch in the cabin so you can disconnect the vsr from the earth so it wont work.
Then if you need it get a solar setup like evil twin down the track.
What does everyone think???
Stupid question though, wouldnt it be better when winching to have the main battery disconnected from the auxillary so that if you screw up and completely drain the main battery you can still link them to be able to start?? and if you are going for this model, instead of having a permanent link ability in your car you could just get a set of jumper leads which then means you can use them to weld, help other people and restart yourself of your aux.
