mudtrolluk
My auto has a 3 way rocking switch, with lights built in;
Up is "Power" orange light and lengthens the shift paten i.e. allow engine to rev higher before changing up and will kick down quicker to lower gear when accelerating , good for towing up or down hills.
Middle is "Auto" no light, standard shift paten, however if you boot it, it will change to "Power" on its own and show orange "Power" light until you back off.
Down is "Hold" green light shortens the shift, so will change gear to a higher gear quicker helping with traction and restricting engine power.
In my (NAF)Haynes manual there is a fault code for the Orange light, when the ignition is turned on the light flashes.
Hope this helps, phil.
